Boeckman, Matthew wrote:
[snip]
>> gdb --args ./nagios /usr/local/nagios/etc/nagios.cfg set
>> follow-fork-mode child r
>> That will allow you to do a backtrace in the child processes
>> if they segfault.
> [New Thread -1211237488 (LWP 24010)]
> [New process 24011]
> Program received signal SIGSEGV, Segmentation fault.
> [Switching to process 24011]
> 0x009b1202 in vasprintf () from /lib/libc.so.6
> (gdb) Caught SIGSEGV, shutting down...
> It loops through that SIGSEGV message until I ctrl-c out. Glibc-2.5-12
> from centos5 install.
Quick question - are you using the standard 3.0b6 release or did you
grab the CVS code this morning? If so, make sure you have the latest
CVS code as I just patched a bug.
Ethan Galstad
Nagios Developer
___
Email: [email protected]
Web: www.nagios.org
