This is a multi-part message in MIME format...
------------=_1104921012-62900-87
Content-Disposition: inline
Dear Folks,
Unfortunately, threaded Perl on FreeBSD 4.x appears unstable.
During a fairly exciting evening of attempting a 1.2 upgrade with
threaded Perl 5.8.5
1 Perl appeared to core dump when syntax checking the plugins (
find /usr/local/nagios/libexec/ -exec grep -q '/bin/perl' -print
| perl -ne 'perl -c $_' sort of thing)
2 Embedded Perl Nag ran for about 10 mins then SEGV'd.
This was in a maintenance window and my technique was poor so there is
no info about the cause of the SEGV. I'll try and run it under gdb on a
suitable occasion.
It's prob a FreeBSD thing rather than Nagios (since 1.2 has been stable
with 5.005_03 for yonks on this platform).
Yours sincerely.
Stanley Hopcroft
IP Australia
Ph: (02) 6283 3189 Fax: (02) 6281 1353
PO Box 200 Woden ACT 2606
http://www.ipaustralia.gov.au
Content-Type: text/plain; name="disclaimer.txt"
Content-Disposition: inline; filename="disclaimer.txt"
MIME-Version: 1.0
X-Mailer: MIME-tools 5.415 (Entity 5.415)
This message contains privileged and confidential information only
for use by the intended recipient. If you are not the intended
recipient of this message, you must not disseminate, copy or use
it in any manner. If you have received this message in error,
please advise the sender by reply e-mail. Please ensure all
e-mail attachments are scanned for viruses prior to opening or
using.
------------=_1104921012-62900-87--
