Re: [Nagios-devel] cisco switches and routers physical port status
=20
You can use regular expressions to select a lot of ports at once (ex :
GigabitEthernet 5/* for all the ports of card 5) with the check_snmp_int
plugin.
=20
Use the C version if you have a big number of interface to use the index
caching capabilities of the plugin.
=20
Info & downloads : http://nagios.manubulon.com
=20
Regards,
=20
Patrick
=20
________________________________
De : [email protected]
[mailto:[email protected]] De la part de rajesh
Envoy=E9 : jeudi 30 ao=FBt 2007 15:33
=C0 : [email protected]
Objet : [Nagios-devel] cisco switches and routers physical port status
withnagios
Hi Guys,
=20
I need to monitor cisco switches and routers physical port status.Can i =
use
check_ifoperstatus plugin or not.One more question my switch port is =
having
25 or 50 ports how do i check the status.This plugin check all =
interfaces by
default or i have to menction each interface.
=20
Thanks for your help
=20
Best Regards
Once upon a time there was 1 GB storage in your inbox. Click here for =
happy
ending.
=20
