--Apple-Mail-120-96780719
Content-Type: text/plain; charset="us-ascii"
Hi Andreas,
On 16 Jan 2013, at 17:37, Andreas Ericsson wrote:
> Well, the story goes like this:
> We would *actually* want to use the recombobulate_*groups() functions,
> but those rely on find_*(), add_member_to_group() and a whole bunch of
> other functions which are inside #ifndef NSCGI (or #ifdef NSCORE).
>=20
> Those functions bring in yet other functions and some of *those* live
> in other files. There are no functions anywhere that reside in the
> base/ directory which have to be linked to the cgi's no matter how far
> down the rabbithole you go, but it's a bit of a mess, really, and
> with the recent improbable-but-possible coredump issue in Nagios core
> I was forced to take a short hiatus from cgi issues and jump on that
> one instead.
>=20
> Anyways; It's unlikely manageable to fix it the proper way. If you
> beat me to a hack that just iterates over the string elements inside
> register_*group(), I think I'll just take that patch instead and put
> a big fat "FIXME this is fugly and should use instead".
I think I've fixed this "properly", as properly as possible. Can you =
review?
Most of the changes are just #ifdefs moved to appropriate places. It =
seems that the parsing of objects.cache was done, just the expansion was =
not. I'm assuming that host/service dependency information is not =
required in the CGIs.
I've also included a test update which checks the CGI are returning the =
object information correctly. svn has marked t/610cgistatus.t as an =
application/x-troff so was not showing the diff correctly. I've included =
as a separate file. Can this be fixed in svn please.
Ton
filename="nagios_fix_cgi_object_relationships.patch"
Content-Type: application/octet-stream; x-unix-mode=0644;
Index: xdata/xodtemplate.c
--- xdata/xodtemplate.c (revision 2581)
+++ xdata/xodtemplate.c (working copy)
@@ -116,12 +116,17 @@
/* xodtemplate id / object counter */
static struct object_count xodcount;
-#ifndef NSCGI
/* reusable bitmaps for expanding objects */
static bitmap *host_map = NULL, *contact_map = NULL;
-#endif
static bitmap *service_map = NULL, *parent_map = NULL;
+/* These variables are defined in base/utils.c, but as CGIs do not need these
+ we just fake the values for this file */
+#ifdef NSCGI
+int use_precached_objects = TRUE;
+int use_regexp_matches = FALSE;
+int use_true_regexp_matching = FALSE;
+#endif
* simple inheritance macros. o = object, t = template, v = variable
@@ -369,6 +374,7 @@
/* cleanup some additive inheritance stuff... */
xodtemplate_clean_additive_strings();
+#endif
/* do the meat and potatoes stuff... */
host_map = bitmap_create(xodcount.hosts);
@@ -380,16 +386,21 @@
if(result == OK)
result = xodtemplate_recombobulate_contactgroups();
+#ifndef NSCGI
if(test_scheduling == TRUE)
gettimeofday(&tv[3], NULL);
timing_point("Done recombobulating contactgroups\n");
+#endif
if(result == OK)
result = xodtemplate_recombobulate_hostgroups();
+#ifndef NSCGI
gettimeofday(&tv[4], NULL);
timing_point("Done recombobulating hostgroups\n");
+#endif
+#ifndef NSCGI
if(use_precached_objects == FALSE) {
if(result == OK)
result = xodtemplate_duplicate_services();
@@ -397,6 +408,7 @@
gettimeofday(&tv[5], NULL);
timing_point("Created %u services (dupes possible)\n", xodcount.services);
+#endif
/* now we have an accurate service count */
service_map = bitmap_create(xodcount.services);
@@ -407,6 +419,7 @@
if(result == OK)
result = xodtemplate_recombobulate_servicegroups();
+#ifndef NSCGI
gettimeofday(&tv[6], NULL);
timing_point("Done recombobulating servicegroups\n");
@@ -5942,6 +5955,7 @@
+#endif
/*************** OBJECT RECOMBOBUL
...[email truncated]...
