It doesn't work in FreeBSD either -- don't get your hopes up. We
reported it over a month ago to no avail. W/O a tracker you're just
pissing in the wind.
~BAS
On Tue, 2008-01-22 at 16:03 +0000, Jan Grant wrote:
> Excuse me mailing the list with this: I can't find any public bug
> tracker and the mailing list archives appear a little light on
> details about this.
> Nutshell version is, just built nagios 2.10 on solaris 10. cfg_dir
> doesn't appear to recurse into directories - as far as I can tell,
> because the cfg_dir code relies on d_type in struct dirent. I can prep a
> patch, but I've no idea whether this is a known issue or fixed or
> whatever.
> Please let me know if this is known, fixed, patch requested, etc, and if
> I'm just being myopic or if there is indeed no bug tracker instance.
> jan
> PS. I appreciate your efforts!
Brian A. Seklecki
Collaborative Fusion, Inc.
