[Nagios-devel] Errors while testing Nagios
--------------090105030401010104070507
From the developer guidelines [1], I ran those commands:
./configure --enable-libtap && make nagios && make cgis && make test
Unfortunately, the compilation fails with the output attached
(output.log) to this message. Can someone enlighten me about the cause
of those errors? They are an extract from "make test_timeperiods" in ./t-tap
I'm also having issues with perl tests in ./t/900-configparsing.t
(test-perl.log). Am I supposed to do something to make those tests pass
out of the box?
Thanks!
[1] http://wiki.nagios.org/index.php/Nagios ... Guidelines
Mathieu
Content-Type: text/plain; x-mac-type="0"; x-mac-creator="0"; name="output.log"
filename="output.log"
gcc -g -O2 -DHAVE_CONFIG_H -DNSCORE -I../include -I../tap/src -o test_timeperiods test_timeperiods.c ../base/utils.o ../base/config.o ../base/macros-base.o ../base/objects-base.o ../base/skiplist.o ../base/xobjects-base.o ../tap/src/tap.o -Wl,-export-dynamic -lm -lpthread -lltdl
../base/utils.o: In function `query_update_api':
/home/mgagne/git/nagios/base/utils.c:4055: undefined reference to `strip'
../base/utils.o: In function `parse_check_output':
/home/mgagne/git/nagios/base/utils.c:2680: undefined reference to `my_strtok'
/home/mgagne/git/nagios/base/utils.c:2687: undefined reference to `my_strtok'
/home/mgagne/git/nagios/base/utils.c:2757: undefined reference to `strip'
/home/mgagne/git/nagios/base/utils.c:2759: undefined reference to `strip'
../base/utils.o: In function `process_check_result_file':
/home/mgagne/git/nagios/base/utils.c:2277: undefined reference to `mmap_fopen'
/home/mgagne/git/nagios/base/utils.c:2292: undefined reference to `mmap_fgets_multiline'
/home/mgagne/git/nagios/base/utils.c:2324: undefined reference to `my_strtok'
/home/mgagne/git/nagios/base/utils.c:2326: undefined reference to `my_strtok'
/home/mgagne/git/nagios/base/utils.c:2420: undefined reference to `mmap_fclose'
../base/utils.o: In function `compare_strings':
/home/mgagne/git/nagios/base/utils.c:2956: undefined reference to `compare_hashdata'
../base/config.o: In function `pre_flight_object_check':
/home/mgagne/git/nagios/base/config.c:1779: undefined reference to `my_strtok'
/home/mgagne/git/nagios/base/config.c:1797: undefined reference to `my_strtok'
/home/mgagne/git/nagios/base/config.c:1950: undefined reference to `my_strtok'
/home/mgagne/git/nagios/base/config.c:1971: undefined reference to `my_strtok'
/home/mgagne/git/nagios/base/config.c:2175: undefined reference to `my_strtok'
../base/config.o:/home/mgagne/git/nagios/base/config.c:2200: more undefined references to `my_strtok' follow
../base/config.o: In function `read_resource_file':
/home/mgagne/git/nagios/base/config.c:1402: undefined reference to `mmap_fopen'
/home/mgagne/git/nagios/base/config.c:1416: undefined reference to `mmap_fgets_multiline'
/home/mgagne/git/nagios/base/config.c:1425: undefined reference to `strip'
/home/mgagne/git/nagios/base/config.c:1428: undefined reference to `my_strtok'
/home/mgagne/git/nagios/base/config.c:1439: undefined reference to `my_strtok'
/home/mgagne/git/nagios/base/config.c:1467: undefined reference to `mmap_fclose'
../base/config.o: In function `read_main_config_file':
/home/mgagne/git/nagios/base/config.c:265: undefined reference to `mmap_fopen'
/home/mgagne/git/nagios/base/config.c:273: undefined reference to `strip'
/home/mgagne/git/nagios/base/config.c:284: undefined reference to `mmap_fgets_multiline'
/home/mgagne/git/nagios/base/config.c:289: undefined reference to `strip'
/home/mgagne/git/nagios/base/config.c:296: undefined reference to `my_strtok'
/home/mgagne/git/nagios/base/config.c:308: undefined refe
...[email truncated]...
