Hello list,
>=20
> The thoughts is that C is a horrible language to use when creating a
> web application. Effort is better spent rewriting select parts of the
> UI in PHP. Ninja is one such effort. I'm sure there are others (Oreon
> comes to mind).
well, I don't agree. And the load on a webserver using C CGIs is
lower than using a interpreted language.
But, on the other side, PHP SSI's may be easier to maintain. Is there
any roadmap regarding the conversion from C to PHP? If you want to, I
can (try to) create a PHP version of the dashboard...
HTH, cu l87r, Edgar.
--=20
( o o )
+-------------------------------------------------.oooO--(_)--Oooo.---+
