[Nagios-devel] NSCA leaving network ports in TIME_WAIT
--Apple-Mail-33-209722911
Content-Type: text/plain;
charset=US-ASCII;
delsp=yes;
format=flowed
Hi!
Has anyone else seen this with the latest NSCA?
Running a send_nsca to an nsca daemon appears to leave a port in
TIME_WAIT state. On my 2.6 Debian and on a Redhat ES4, after I've run
a send_nsca, I get in netstat -an:
tcp 0 0 127.0.0.1:52940 127.0.0.1:10123
TIME_WAIT
(I'm testing on port 10123, though it also occurs on port 5667).
Weirdly enough, this port is not left open on Mac OS X 10.4.4.
This also happens with NSCA 2.4.
I've attached a tar which is to be dropped into the top level of the
nsca tarball. This has a subdirectory called tests and if you change
in there and run "make test", it will run the test. Ethan, maybe you
could include this in the distribution as a sanity test. I plan on
adding to the tests, including a stress test.
Ton
http://www.altinity.com
T: +44 (0)870 787 9243
F: +44 (0)845 280 1725
Skype: tonvoon
Content-Type: application/x-tar;
x-unix-mode=0644;
name="nsca_tests.tar"
filename=nsca_tests.tar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...[email truncated]...
