Re: [Nagios-devel] Event broker question
Justin Amburn wrote:
> Hi all,
> Has anyone written any custom Event broker modules?
I've written plenty (seven or eight, iirc).
> Does anyone have a
> sample module that can call an external shell command when anything
> 'critical' happens?
I doubt it, but as Johannes says you can do that with eventhandlers
(or notification-scripts).
However, if you were to inform us as to what your end-goal is, you're
far more likely to get an answer that
a) Makes sense.
b) May not relate to event-broker modules at all.
c) Actually solves your problem.
YMMV though, but good luck even so.
OP5 AB www.op5.se
on peace.
