Re: [Nagios-devel] status.cgi segfault without hostgroup parameter
On 09/29/2010 05:03 PM, Michael Friedrich wrote:
>> In the meantime, we both maintain git repositories with separate
>> branches for our
>> own development. Mine is rebased onto master every once in a while, so
>> it shouldn't
>> be considered a stable base for development.
>> You'll find mine at
>> git://git.op5.org/nagios.git dev
>> I'll rebase that one later today though, and possibly submit the patches to CVS
>> via the export-commit functionality in git.
> Yep, i've evaluated and partly merged them. Some caused problems (neb
> module my_fcopy hacks, when loading more than one module), but I did not
> get the time to look deeper into them. Although I will after getting
> Icinga release done and stepping onto unstable branch. I'll get back to
> you then :)
Yea, I discovered that one too when debugging an install with multiple
modules. Since the module loading still works it went by unnoticed for
quite a long time though. I'm working on fixing it right now actually,
in parallell with hacking up config sync for merlin.
OP5 AB www.op5.se
on peace.
