On 01/07/2011 12:47 PM, Michael Friedrich wrote:
> Andreas Ericsson wrote:
>>>> On 01/03/2011 03:13 PM, Carsten Emde wrote:
>>>> Applied and pushed. Thanks
>>> Nice patch, thanks. It contains several inline declarations which i have
>>> reworked while applying against Icinga CGIs. Attached is a git patch against
>>> current Nagios HEAD (from git.op5.org, thx for the mirror) resolving those
>>> things too.
>> This patch is kinda backwards. It's considered best practice to have the
>> variables declared inside the outmost block they're used, so as to prevent
>> value spilling when the code is next modified.
> It is?
Yes. It allows the compiler to optimize the code better and prevents bugs
caused by reusing variables.
OP5 AB www.op5.se
on peace.
