Re: [Nagios-devel] Patch: Multiline perfdata lacks trailing blanks
Thanks Matthias - Patch will be in CVS shortly.
Matthias Flacke wrote:
> Hi Ethan, hi list,
> for a new 3.x plugin I use the feature to specify multiple lines of
> performance data as described in
> http://nagios.sourceforge.net/docs/3_0/pluginapi.html
> Example:http://www.my-plugin.de/wiki/doku.php/c ... ended_info
> There is a small bug in utils.c which misses to add trailing blanks
> while sticking them together into $SERVICEPERFDATA$.
> I attached a small patch to add these blanks.
> Kind regards,
> Matthias
Ethan Galstad,
Nagios Developer
Email: [email protected]
