Re: [Nagios-devel] NRPE DB2 Alerts displayed but not escalated
Trevor Warren wrote:
> Morning Friends,
> We are using Nagios with NRPE on the remote servers(AIX 5.2 and RHEL
> 3) which capture information with respect to DB2 and escalate the
> same to the Central Nagios host. The process is as following:
Please move this to the nagios-users mailing list instead.
>> The sed/awk/bash scripts on the DB2 servers get the DB2 stats and
>> create the requisite text files with the stats in it. Nagios Nrpe
>> does a cat of the file on the remote machine and pulls the
>> information across to it. The message are either of the type: "DB2
>> Buffer Pool Hit Ratio WARNING : Buffer Pool Hit Ratio Low" or "DB2
>> Buffer Pool Hit Ratio OK : Buffer Pool Hit Ratio Low Fine".
> But irrespective of which message nrpe pulls from the DB2 servers all
> you can see is the services showing up via the nagios web interfaces
> in "OK" in green. This is a lil nausseating, i know its a config
> issue on my part but i cant figure out what i should be passing via
> NPRE to nagios such that it displays the "Warnings" in Yellow and
> "Critical" in Red.
> Please suggest. Thanks in advance guys.
> Trevor
OP5 AB www.op5.se
Lead Developer
