> to
> the failed service in the notification message. This might actually
> help
> fault diagnosis. For example, if you receive separate notifications
> that 4
> machines behind the same router have gone down at the same time, then
> you
> might assume that the router might be at fault.
>=20
> At the moment, with the current notification architecture, I don't
> think
> you can have enough information to do that, without looking at the
> status
> CGIs or knowing from memory that the hosts are all behind the same
> router
> (which doesn't scale well
I believe what your talking about is already implemented here
http://nagios.sourceforge.net/docs/1_0/ ... ility.html
If the parent of a host goes down, notifications of its children will be
suppressed.
Forgive the Outlook mangling,
- matt
