[Nagios-devel] problems epn with 3.0a1
Hi all together,
I have some problems getting the embedded perl interpreter running with
nagios 3.0a1. I'm using RHEL4.
When switching the
DEBUG_LEVEL => LEAVE_MSG | CACHE_DUMP | PLUGIN_DUMP
in p1.pl, I get messages in epn_leave-msgs.log, where everything seems
to be fine. I can see the plugin called, I can see the result of the
plugin.
Wed Mar 21 11:09:29 2007 eval_file: successfully compiled "/usr/local/nagios/libexec/WL/check_snmp_cisco_ifstatus -H 10.33.255.33 -C readcommunity -N 10101 -w 400000000 -c 500000000 -b wlswi5c -s IF_01".
Wed Mar 21 11:09:29 2007 run_package: "/usr/local/nagios/libexec/WL/check_snmp_cisco_ifstatus -H 10.33.255.33 -C readcommunity -N 10101 -w 400000000 -c 500000000 -b wlswi5c -s IF_01" returning (0, "IFStatus is OK - THROUGHPUT OK: - GigabitEthernet0/1 (ethernet) - In: 0 Mbps, Out: 0.017 Mbps, Limit: 1000 Mbps|in=0;0;400000000;500000000;1000000000 out=17000;0;400000000;500000000;1000000000 errors=0").
Wed Mar 21 11:09:31 2007 eval_file: successfully compiled "/usr/local/nagios/libexec/WL/return3.pl ".
Wed Mar 21 11:09:31 2007 run_package: "/usr/local/nagios/libexec/WL/return3.pl " returning (3, "Undefined (dummy Messages) ").
Wed Mar 21 11:09:31 2007 eval_file: successfully compiled "/usr/local/nagios/libexec/WL/check_snmp_load -H 10.33.255.4 -C wlrouter -w 50 -c 70 -T alteon -f".
Wed Mar 21 11:09:35 2007 eval_file: successfully compiled "/usr/local/nagios/libexec/WL/return2.pl ".
Wed Mar 21 11:09:35 2007 run_package: "/usr/local/nagios/libexec/WL/return2.pl " returning (2, "Critical (dummy Messages) ").
Wed Mar 21 11:09:37 2007 eval_file: successfully compiled "/usr/local/nagios/libexec/WL/return3.pl ".
Wed Mar 21 11:09:37 2007 run_package: "/usr/local/nagios/libexec/WL/return3.pl " returning (3, "Undefined (dummy Messages) ").
Wed Mar 21 11:09:39 2007 eval_file: successfully compiled "/usr/local/nagios/libexec/WL/return3.pl ".
Wed Mar 21 11:09:39 2007 run_package: "/usr/local/nagios/libexec/WL/return3.pl " returning (3, "Undefined (dummy Messages) ").
Inside Nagios the Return-Status of the check ist fine aswell, (OK is OK, WARNING is WARNING etc.) but the
first few bytes of the serviceoutput seems to be missing.
[SERVICEPERFDATA] 1174471774 wlswi5c IF_01 0.101 0.135 8 is OK - THROUGHPUT OK: - GigabitEthernet0/1 (ethernet) - In: 0 Mbps, Out: 0.017 Mbps, Limit: 1000 Mbps in=0;0;400000000;500000000;1000000000 out=17000;0;400000000;500000000;1000000000 errorsÐ
[SERVICEPERFDATA] 1174471774 wlswi1a IF_05 0.005 0.135 fined (dummy Messages)
[SERVICEPERFDATA] 1174471784 wlswi5a IF_04 0.004 0.308 8ical (dummy Messages)
[SERVICEPERFDATA] 1174471784 wlswi6a IF_05 0.005 0.308 ¸fined (dummy Messages)
[SERVICEPERFDATA] 1174471784 wlswi3a IF_05 0.004 0.308 fined (dummy Messages)
Is there anyone else, who has seen that behavior, may be on other OS,
Thanx for answers,
Peter
