Hendrik,
Thanks for pointing this out. I had not seen this patch. We have been =20
using the below patch since early version of 2.0 so this was an update =20
to that. The only difference between the two really is that with a =20
patch to status.cgi my patch keeps any of the links from being =20
displayed. The can_submit_commands patch completes this on the =20
auth.cgi so you get a message when you click that link. I think I =20
should be able to combine their efforts and mine and get the best from =20
both worlds. I will see if I can merge mine to use can_submit_commands =20
base this week and send in the update.
Derrick
Quoting Hendrik B=8A=E4cker :
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi Derrick,
> local.coder schrieb:
> | This patch will provide for a new option in cgi.cfg
> | authorized_for_read_only=3D,
> | Any Nagios userid listed in the above cgi variable will be limited to
> | Read only CGI Access.
> | This will block any service or host commands normally shown on the
> | extinfo pages.
> | This will also block any service or host based comments from being shown
> | to read only users.
> I guess this is obsolete.
> Or isn't it this:
> http://nagios.sourceforge.net/docs/3_0/ ... ml#contact
> (have a look for can_submit_commands)
> Cheers,
> Hendrik
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.8 (Darwin)
> iEYEARECAAYFAkiikVEACgkQlI0PwfxLQjlT3QCeIttIYPE7NoiY0Y8yPzFKVn0c
> 4ecAmQHRH4C5+5uEyZqb/CQ6D3d9dWDu
> =3Dg9Pw
> -----END PGP SIGNATURE-----
> This SF.Net email is sponsored by the Moblin Your Move Developer's challen=
ge
> Build the coolest Linux based applications with Moblin SDK & win great pri=
zes
> Grand prize is a trip for two to an Open Source event anywhere in the worl=
d
> http://moblin-contest.org/redirect.php? ... 00&url=3D/
> Nagios-devel mailing list
> [email protected]
