Re: [Nagios-devel] Problems with many hanging Nagios
Mahesh Kunjal wrote:
> We had similar issue. We have a distributed environment with one master and 4 slaves. Total number of hosts monitored are 1900+ and
> 20000+ services spread across 4 slaves.
> At times we saw 14K or more results being sent in a second from slaves. This resulted in 100+ nagios processes being created.
> Changed reaper frequency to 2 seconds and played with all tunables.
> Nothing seemed to help.
> Looking at the nagios source,
> This is what I found out was happening...
> Nagios has a commands file worker thread and when it gets woken up, looks if there is data in pipe(nagios.cmd), if exists, forks a child process. This will be in a loop and checks the pipe for data.
> Now what does the forked nagios child process do?
> It reads all the data from the pipe one message a time and puts it in commands buffer. If if is able to write to buffer, just exits.
> The problem here was command buffer had a limited size of 1024. This is the default setting in include/nagios.h.in and is in the line #define COMMAND_BUFFER_SLOTS 1024.
This is the number of buffers that will be available for writing into,
not the number of total bytes available. Each command buffer slot holds
MAX_INPUT_BUFFER bytes.
> This was not enough and the child process started to wait for memory to be freed so that the pipe data retrieved can be put in buffer.
> While this child process waited for memory to be freed, the command worker thread got woken up and realized that there is data in pipe and forked another child. This got repeated and eventually server went out of memory.
A very concise and correct description of what's going on. Thanks.
> Here is what we did to resolve.
> 1. Edit the include/nagios.h.in
> change
> to
> #define COMMAND_BUFFER_SLOTS 60000
> And change
> #define SERVICE_BUFFER_SLOTS 1024
> to
> #define SERVICE_BUFFER_SLOTS 60000
This would indeed solve the problem, although you could have gotten away
with the same amount of SERVICE_BUFFER_SLOTS as there are services
configured on the system, and the same amount of COMMAND_BUFFER_SLOTS as
there are hosts and services. Provided the slaves also send passive
hostchecks, ofc, otherwise you can set it to the amount of services instead.
It should also be noted that these settings shouldn't be modified unless
needed, as it will make Nagios use quite a bit more memory per default.
OP5 AB www.op5.se
