I get an error when trying to deploy nagios to my ESX. The error was hit when i try to do the convert. I have attached the error i encountered. Is this because the files got corrupted ? or cause by my vm converter ?
Thanks.
Regards,
Hardy
Try to deploy NagiosIX on ESX
- error.JPG (68.94 KiB) Viewed 1958 times
Re: Try to deploy NagiosIX on ESX
This is a known issue with VMware. You will need to convert VMware player files to ESXi format first.
http://communities.vmware.com/thread/211860
