Re: [Nagios-devel] [PATCH] - 3.0.3: only send out a service
Thomas,
I think I have a resolution to the
tracked escalation state -> non-escalation state 1 ... N -> escalation
recovery -> send recovery
issue you brought up.
In my testing environment I have added code to the patch that will do
the following if the previous problem state is *not* listed explicitly
in the escalation definition:
* If service_history_index > 0
** Walk backwards through the state history for the service no farther
than to the value for first_notification for the current escalation
*** If any state in the backwards walk matches a state listed in the
escalation definition, then send a recovery notification as that means
we did send an escalation notification for a problem *within the scope
of the current escalation definition*
Do you see any problems with this additional logic? So far it is
working for me in my test environment, which has the same configs as
our prod environment.
Regards,
Max
