Re: [Nagios-devel] TRUE and FALSE
On Mon, 2005-04-18 at 08:46 -0700, Ben wrote:
> Sorry, I'm too busy to go on a scavenger hunt. :) What do they do there?
Please, sit down before!
From http://net-snmp.sourceforge.net/docs/mibs/IF-MIB.txt:
---- snip ----
ifPromiscuousMode OBJECT-TYPE
SYNTAX TruthValue
MAX-ACCESS read-write
STATUS current
DESCRIPTION
"This object has a value of false(2) if this interface only
accepts packets/frames that are addressed to this station.
This object has a value of true(1) when the station accepts
all packets/frames transmitted on the media. The value
true(1) is only legal on certain types of media. If legal,
setting this object to a value of true(1) may require the
interface to be reset before becoming effective.
The value of ifPromiscuousMode does not affect the reception
of broadcast and multicast packets/frames by the interface."
::= { ifXEntry 16 }
---- snip ----
This doesn't sound too bad.
The main reason may be that you are not allowed to have an index == 0 in
MIB tables (than it would be a scalar AFAIK).
From http://rfc.net/rfc1471.html
---- snip ----
pppLinkConfigMagicNumber OBJECT-TYPE
SYNTAX INTEGER {false (1), true (2)}
ACCESS read-write
STATUS mandatory
DESCRIPTION
"If true(2) then the local node will attempt to
perform Magic Number negotiation with the
remote node. If false(1) then this negotiation
is not performed. In any event, the local node
will comply with any magic number negotiations
attempted by the remote node, per the PPP
specification. Changing this object will have
effect when the link is next restarted."
REFERENCE
"Section 7.6, Magic Number, of RFC1331."
DEFVAL { false }
::= { pppLinkConfigEntry 4 }
---- snip ----
Have fun!
> And are you talking about the SNMP MIB itself, or the SNMP daemon?
The SNMP-MIBs itself and *not* the deamon (actually which one do you
mean?).
> Because I would imagine SNMP might let you define true and false more
> abstractly than non-zero and zero..... but we're talking C here.
Of course. And you want to define it to two values. But IMHO it does not
help if you define the same concept (numerical representation of boolean
values) in different ways depending on the phase of the moon ....
Bernd
Firmix Software GmbH http://www.firmix.at/
mobil: +43 664 4416156 fax: +43 1 7890849-55
Embedded Linux Development and Services
