Re: [Nagios-devel] Patchs proposal
Ton Voon wrote:
> On 17 May 2009, at 14:20, Andreas Ericsson wrote:
>> I modified it quite extensively, but I've committed
>> it to Nagios CVS. The effects of it will be in the next nagios
>> release,
>> but the exact code you wrote is not there. Check out latest CVS and
>> have a look in base/config.c and you'll see how it turned out.
> I'm getting an error when I run "make nagios" where it says:
> Undefined symbols:
> "_xodtemplate_unset_service_is_from_hostgroup", referenced from:
> _xodtemplate_begin_object_definition in xobjects-base.o
> I've done a "make distclean && ./configure && make nagios" and I still
> get this problem. Presumably this is working for your system?
Well, it did, but I screwed up and forgot to commit moving the macros
to the top of the file before I ran cvsexportcommit, and I didn't run
git-push until now (which would have caught it, as my pre-push hook
runs some basic tests).
I'll make a mental note to not use the -c option to that command and
test-build things from the CVS directory instead.
OP5 AB www.op5.se
Register now for Nordic Meet on Nagios, June 3-4 in Stockholm
http://nordicmeetonnagios.op5.org/
on peace.
