[Nagios-devel] Re: [Nagios-users] Adaptive monitoring commands
The external command documentation is currently being rewritten and
will (hopefully correctly) document all the external commands that
Nagios supports. The following syntax is correct:
CHANGE_SVC_CHECK_COMMAND;;;
It probably didn't work so well, as I just found that issuing this
command caused a SEGFAULT. A fix will be in CVS shortly.
On 1 Apr 2005 at 13:40, Chris Hale wrote:
> Has anyone had luck getting the new adaptive monitoring commands in
> 2.0 to work?
> In particular I'm trying to get the CHANGE_SVC_CHECK_COMMAND to work.
> The documentation has the command like this:
> CHANGE_SVC_CHECK_COMMAND:command_name
> But how does it know which host and service to apply this too?
> Thinking that this was just a documentation oversight... I've tried:
> CHANGE_SVC_CHECK_COMMAND;;; COMMAND>
> too make it match what the other external commands look like... the
> command shows up in the event log, but no change happens in the actual
> check.
> On a site note...
> Adding a hostname to CHANGE_HOST_CHECK_COMMAND seems to work ok, so
> I'm wondering if there is something wrong with this command.
> SF email is sponsored by - The IT Product Guide
> Read honest & candid reviews on hundreds of IT Products from real
> users. Discover which products truly live up to the hype. Start
> reading now. http://ads.osdn.com/?ad_id=6595&alloc_id=14396&op=click
> _______________________________________________ Nagios-users mailing
> list [email protected]
> https://lists.sourceforge.net/lists/lis ... gios-users ::: Please
> include Nagios version, plugin version (-v) and OS when reporting any
> issue. ::: Messages without supporting info will risk being sent to
> /dev/null
Ethan Galstad,
Nagios Developer
Email: [email protected]
