[Nagios-devel] Patch by Dougal Scott (MySQL History Log)
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_001_01C28F18.50574980
Content-Type: text/plain;
charset="iso-8859-1"
interesting, I'll give it a try when I get into the office.
-----Original Message-----
To: Bryan Liles; [email protected]
Sent: 11/18/2002 10:31 AM
Subject: RE: [Nagios-devel] Patch by Dougal Scott (MySQL History Log)
Problem Compiling
Yes, it went all the way through smoothly.
Maybe a problem: I'm using the current CVS snapshot- not the 1.06b
release.
Greetings
Daniel
Sent: Monday, November 18, 2002 4:29 PM
To: 'Daniel Geske '; '[email protected] '
Problem Compiling
Just curious, I have been using this patch with no problems at all. Did
your patch apply cleanly?
To: Daniel Geske; [email protected]
Sent: 11/18/2002 6:21 AM
Problem Compiling
Hi again,
does anybody have an idea on how to fix this problem? Do you need more
specific information (if yes, which) on it?
Thank you all very much.
Greetings
Daniel
[mailto:[email protected]]On Behalf Of Daniel
Geske
Sent: Monday, November 11, 2002 11:21 AM
To: [email protected]
Subject: [Nagios-devel] Patch by Dougal Scott (MySQL History Log)
Problem Compiling
Hi all,
I'm trying to use Dougal Scott's patch to log nagios history info to
mysql
db.
First off, I cvsed a fresh nagios. Applying the patch went OK, no
problems.
First thing I notice comes up when I run configure. It's supposed to
echo
"We'll use MySQL database routines (in xdata/xlogdb.*) for history log"
between the lines for comment data and extended data, but doesn't.
Then, of course, it doesn't show it's planning to use xlogdb in the
configuration summary either. First line after "Web Interface Options"
should be "History Log data: $XLOGCOMMENT". Instead, I get the normal
"HTML
URL: ..." There are no error messages. The first error I get in this
procedure is when I run "make all". Maybe the output there can help. For
all
command outputs, please see below.
I have checked wheather there it may use the wrong configure.in file,
well
there's only one in my nagios source dir (the patched file), so I assume
it's using it, too.
How can I compile nagios so it stores it's history logs in a MySQL DB
now?
I'm looking forward to hearing from you all. Thanks.
Sincerely
Daniel
$ ./configure [..] --with-mysql-historylog [..]
We'll use MySQL database routines (in xdata/xsddb.*) for status data
I/O...
We'll use MySQL database routines (in xdata/xcddb.*) for comment data
I/O...
We'll use MySQL database routines (in xdata/xeddb.*) for extended data
I/O...
We'll use MySQL database routines (in xdata/xrddb.*) for retention data
I/O...
We'll use template-based routines (in xdata/xodtemplate.*) for object
data
I/O...
We'll use file-based routines (in xdata/xpdfile.*) for performance data
I/O...
We'll use MySQL database routines (in xdata/xdddb.*) for scheduled
downtime
data I/O...
*** Configuration summary for nagios 1.0b6 09-15-2002 ***:
Web Interface Options:
HTML URL: http://localhost/nagios/
CGI URL: http://localhost/nagios/cgi-bin/
Traceroute (used by WAP): /usr/sbin/traceroute
$ make all
gcc -g -O2 -I/usr/include/mysql/ -I/usr/local/include/
-fno-strict-aliasing
-I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64
-I/usr/lib
/perl5/5.6.1/i586-linux/CORE -DHAVE_CONFIG_H -DNSCORE -L/usr/lib/mysql/
-L/
usr/lib/ -lmysqlclient nagios.c checks.o config.o commands.o flapping.o
logging.o notifications.o sehandlers.o utils.o sretention.o
../xdata/xrddb.
...[email truncated]...
