[Nagios-devel] Front End Development
------_=_NextPart_001_01C8C595.66BC718F
Content-Type: text/plain;charset="us-ascii"
I have tried searched high and low for documentation regarding the way a
Front End should communicate with Nagios 3.x ( even 2.x ), but with no
avail. If anyone has a site or a quick run down on where to start I
would appreciate it.=20
=20
=20
A side note, I started by simply parsing the Nagios log files for the
information I wanted, but decided that it may not be the correct way to
do it and have halted at that point to research some better alternatives
and methods.=20
This message is intended solely for the person or entity to which it is a=
ddressed and may contain confidential and/or privileged information.
Electronic information transmitted herein is not a guarantee of commitmen=
t whatsoever or is legally binding unless explicitly noted otherwise. Any=
review, dissemination, copying, printing or other use of this message =
by persons or entities other than the addressee is prohibited.
If you have received this message in error, please contact the sender imm=
ediately and destroy the material immediately.
Content-Type: text/html;charset="us-ascii"
regarding the way a Front End should communicate with Nagios 3.x  ( =
even 2.x ),
but with no avail. If anyone has a site or a quick run down on where to s=
tart I
A side note, I started by simply parsing the Nagios lo=
g files
for the information I wanted, but decided that it may not be the correct =
way to
do it and have halted at that point to research some better alternatives =
and
methods.
This message is intended solely for the person or entity to which it =
is addressed and may contain confidential and/or privileged information.
------_=_NextPart_001_01C8C595.66BC718F--
