[Nagios-devel] RFC: Conditional macros in object configuration
------=_NextPart_000_041D_01C78E5F.C3A4C020
Content-Type: text/plain;
charset="us-ascii"
Hi List,
I know it's a bit late in Nagios 3 development process to suggest such a
feature, but I see great advantage of implementing this so I'm asking others
if they feel this should go in Nagios 3 as well.
First some background. For some time now I've defined various check commands
that look like this:
check_command $USER1$/check_something -H $HOSTADDRESS$ -p $ARG1$ 80
--other-arguments
While I knew since the beginning that this was definitely a hack, it worked
and I never complained. But as my setups get more complex I needed to define
more "optional args" and it doesn't always work. Also since these hacks are
totally unsupported they can easily break on Nagios-plugins upgrades and
sometimes produce unexpected results when you least expect them.
What I'd like to see is ways to define optional and conditional macros.
There's two things that could be done.
1. Bash-style conditional macros
check_command -H $ARG1|HOSTADDRESS$ -p $ARG1|_DEFAULTHTTPPORT$
More complex ones: $(_OPT1&_OPT2)|(_OPT3|_OPT4&_OPT5)$
Basically the same using || and && in bash.
2. C-style conditional macros
$ARG1?-p $ARG1$:-p 80$
$ARG1?-p $ARG1$:$
What do you think? I'm very open to changes in the syntax; what I'm
suggesting is only the feature no matter how it's implemented...
Does it sounds like a good idea?
Thomas
Content-Type: application/x-pkcs7-signature;
name="smime.p7s"
filename="smime.p7s"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...[email truncated]...
