Re: [Nagios-devel] Event handlers functionality reapplied to Nagios
On 02/25/2013 04:31 PM, Ton Voon wrote:
> Andreas,
> We've noticed that the event handlers do not currently work in Nagios
> 4 trunk. It seems that there is a FIXME message where the worker part
> was not implemented.
I just tested this, and event handlers work properly here. Granted, my
test only involves running a command that writes a few lines to a file,
so it finishes quickly and never fails.
In what way do you consider them broken?
> We've now implemented this, so I think this is now working as
> expected.
> Please find the patch below, nagios_4_support_event_handlers.patch.
> This applies on top of the envvar support we added for Nagios 4
> (subject "Fix default value for enable_environment_macros") which is
> reattached as nagios_macro_environents_in_command_definition.patch.
> Are there any other things that are not implemented yet that you
> would like some assistance with?
Downtime and comment handling needs a complete rewrite to avoid O(xn)
removal time. A doubly linked list would do the trick. We can add a
fan-out table later. Note that you'll have to do clever tricks with
a container_of() macro to get a doubly linked list without breaking
the ABI though. Using the fact that the first entry of a struct
always has the same address as the struct should do the trick.
The query-handler could use a macro-substitution service.
The existing nerd-channels should take a format-string to replace
macros and whatnot before shipping the data to its subscriber. It
should also print neater output by default.
OP5 AB www.op5.se
on peace.
