Re: [Nagios-devel] Adding host & services while Nagios daemon is
--Apple-Mail-1--882728045
Content-Type: text/plain;
charset=ISO-8859-1;
delsp=yes;
format=flowed
On Apr 20, 2007, at 11:50 AM, Sebastian Ganame wrote:
> So, what I would need is to add new hosts (and maybe new services) =20
> to be monitored while Nagios is running.
What about using the HUP signal to nagios?
Modify the configuration, check for errors using nagios -s nagios.cfg.
then
kill -HUP `cat /your/nagios.pid`
That will reload the configuration, adding or removing services or =20
hosts to the current nagios instance.
--=20
Sergio Guzm=E1n
San Jos=E9, Costa Rica
Tel: (506) 258-5757
http://www.gridshield.net/
Gridshield: Protecci=F3n y Monitoreo de Redes
Content-Type: text/html;
charset=ISO-8859-1
On Apr 20, 2007, =
at 11:50 AM, Sebastian Ganame wrote:So, what I would need is to add new hosts (and maybe =
new services) to be monitored while Nagios is =
running.What about using the HUP =
signal to nagios?Modify the configuration, =
check for errors using nagios -s =
nagios.cfg.then=A0kill -HUP `cat =
/your/nagios.pid`That will reload the =
configuration, adding or removing services or hosts to the current =
nagios instance. --=A0Sergio =
Guzm=E1nSan Jos=E9, Costa RicaTel: (506) 258-5757http://www.gridshield.net/Gridshield: Protecci=F3n y Monitoreo de =
Redes</S
...[email truncated]...
