I'm a little bit late, but I've seen in the archive the mail from Scott
Brynen ( http://sourceforge.net/mailarchive/mess ... id=9215796
) about the double log rotation bug when the system clock is
compensated backward.
I still have the same problem (Nagios v1.2), and I thought the simple
following patch could help. (Or has this been handled in v2.0, or
anywhere else?)
The idea is quite simple, just do not adjust log rotation events (as
they must occur at an absolute time, not relative). It's one more "if",
following diff with context:
nagios-1.2/base # diff -c nagios.c.old nagios.c
*** nagios.c.old Tue Sep 20 18:16:05 2005
--- nagios.c Tue Sep 20 18:17:44 2005
*** 1827,1846 ****
/* adjust the next run time for all high priority timed events
for(temp_event=event_list_high;temp_event!=NULL;temp_event=temp_event-
>next){
! /* we moved back in time... */
! if(last_time>current_time){
! /* we can't precede the UNIX epoch */
! if(time_difference>(unsigned
long)temp_event->run_time)
! temp_event->run_time=(time_t)0;
! else
temp_event->run_time=(time_t)(temp_event->run_time-
(time_t)time_difference);
! /* we moved into the future... */
! else
>run_time+(time_t)time_difference);
/* adjust the next run time for all low priority timed events */
for(temp_event=event_list_low;temp_event!=NULL;temp_event=temp_event-
>next){
--- 1827,1848 ----
>next){
! if(temp_event->event_type!=EVENT_LOG_ROTATION){
! if(time_difference>(unsigned long)temp_event->run_time)
! else
! else
>next){
Any feedback/flame is welcomed!
Steph
