[Nagios-devel] How to acknowledge a notification from external command file
------=_NextPart_000_000B_01C40A95.D2A637D0
Content-Type: text/plain;
charset="iso-8859-1"
I am looking for the command Service Acknowledgement and Host =
Acknowledgement to a notification using the External Command file though =
this is possible from the CGI interface there does not appear to be any =
acknowledgement command(s) listed in the External Command documentation.
=20
I have search the documentation and the mail lists and could not find =
anything though there is a couple of routines in the nogios code, =
cmd_acknowledge_problem and cmd_remove acknowledgement, that seems to =
imply that this may be supported.
=20
Is there a way to acknowledge a notification using the External Command =
file ?
=20
Thanks.
Paul Futscher
Content-Type: text/html;
I am looking for =
the command=20
Service Acknowledgement and Host Acknowledgement to a notification using =
the External Command file though this is possible from the CGI =
interface=20
there does not appear to be any acknowledgement command(s) listed in the =
I have search the =
documentation and=20
the mail lists and could not find anything though there is a couple of =
routines=20
in the nogios code, cmd_acknowledge_problem and cmd_remove =
acknowledgement, that=20
seems to imply that this may be supported.
Is there a way to =
acknowledge a=20
notification using the External Command file ?
Thanks.
Paul =
Futscher
------=_NextPart_000_000B_01C40A95.D2A637D0--
