[Nagios-devel] =?iso-8859-1?Q?ENC:_Histogram_graphic_don=B4t_show_lines_when_event_numbe?=
------=_NextPart_000_003C_01C2A06D.43822FC0
Content-Type: multipart/alternative;
boundary="----=_NextPart_001_003D_01C2A06D.4383B660"
------=_NextPart_001_003D_01C2A06D.4383B660
Content-Type: text/plain;
charset="iso-8859-1"
I think i=B4ve sent the e-mail below to the wrong list.
=20
Attached there=B4s a copy of the histogram graph, to better illustrate
what happens...
=20
If some of you could lend me a hand, TIA.
=20
SMV
-----Mensagem original-----
De: Sandro Merg Vaz [mailto:[email protected]]=20
Enviada em: sexta-feira, 6 de dezembro de 2002 11:37
Para: '[email protected]'
Cc: 'Alessandro Ren'
Assunto: Histogram graphic don=B4t show lines when event numbers are =
high
Hello all!
=20
Today i was generating some alert histogram reports, and some weird
thing has happened...
=20
When the number of recovered, down and unreachable events are higher
than 200 (in a day or month), for example, the lines in the histogram
alerts don=B4t show up. If these values are lower than these limit,
everything seems fine...=20
I believe that=B4s is a Y-scale problem, because when the lines =
doesn=B4t
appear, the Y-scale numbers doesn=B4t appear too...
=20
I also looked int the code of histogram.c to see if there is a max
number of events that this program is able to process, but i=B4ve found
nothing.
=20
Is it a known bug? I=B4ve also looked at the mailing list, but didn=B4t =
find
nothing closer to my problem...
=20
Any help or idea?,
=20
TIA,
=20
Sandro Merg Vaz=20
InterOp Inform=E1tica
Divis=E3o OpServices
Fone: (+55) 51 3216-7000=20
Fax : (+55) 51 3216-7001=20
e-mail: HYPERLINK
"mailto:[email protected]"[email protected]=20
HYPERLINK "http://www.interop.com.br/"http://www.interop.com.br
**********************************=20
"It requires wisdom to understand wisdom:=20
the music is nothing if the audience is deaf. "
Walter Lippmann=20
=20
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.426 / Virus Database: 239 - Release Date: 2/12/2002
Version: 6.0.427 / Virus Database: 240 - Release Date: 6/12/2002
=20
=20
Content-Type: text/html;
Mensagem
I=20
think i=B4ve sent the e-mail below to the wrong =
list.
Attached there=B4s a copy of the histogram graph, to better =
illustrate what=20
happens...
If=20
SMV
-----Mensagem original-----De: Sandro Merg Vaz=20
[mailto:[email protected]] Enviada em: sexta-feira, 6 =
de=20
dezembro de 2002 11:37Para:=20
'[email protected]'Cc: 'Alessandro=20
Ren'Assunto: Histogram graphic don=B4t show lines when event =
numbers=20
are high
Hel
...[email truncated]...
