hardware and software Requirements
Hi all i install the nagios xi but when i run the application my pc freez i just want to know the hardware and the software requirements to install and run the nagios xi in a machine
Re: hardware and software Requirements
We need a little more information in order to answer your question:
Are you using our pre-installed VM, or a manual install?
If manual, which distro, and what kind of hardware specs are on this machine.
What do you mean by:
The more detail you give the better we can help.
Which PC? The XI server, or the machine that's accessing the interface from the web browser?when i run the application my pc freez
Sorry for the previous message as it was not clear at all
i run nagiosxi on microsoft virtual pc on windos xp
4 cpu with 32 bits and 1 G RAM
when i put the ip address in the browser and after i log in the nagios interface appear and then the page become freez cannt access any icon
so i want to know if there is a preriquirements
tonyyarusso
I've generally had to assign at least 768MB of RAM to the virtual machine for it to run stably, so 1GB wouldn't be enough to run that, the hypervisor, and your host OS. 2GB probably would, depending on how much else you have going on in the host OS. Basically you'll want to add between 512MB and 1GB to whatever your host requirements are.
