Re: [Nagios-devel] Message passing between host/service check
--------------040302080504070802040305
Content-Type: text/plain; charset=UTF-8; format=flowed
Hi again....
With the risk of getting off topic:
I don't want to maintain Cacti too, if i have to check the interface for
status, i
might as well do the performance stuff too, in the same plugin.
One other post suggested memcache, or database. I will stick with my
quick&dirty
/tmp files.... ;)
Eli Stair wrote:
> I haven't messed with the ndo at all (which may be able to store
> arbitrary data for a host in a table?), but if you use cacti to do
> your snmp polling, you not only get nice trending data visually, but
> can use db acceses for the host if you want yo look up further data...
> Or just pull the values you want our of the rrd for that host:if
> /eli
> -----Original Message-----
> From: [email protected]
> To: [email protected]
> Sent: Thu Oct 19 11:30:28 2006
> Subject: [Nagios-devel] Message passing between host/service check plugin.
> Hi Group,
> Am i the only person in here needing a way to pass someting to a
> check plugin,
> from the last invocation ?
> I don't like using snmp OID values for my plugin executions, som i
> use the interfacename
> to poll the status via SNMP. To do this i have to walk the ifDescr
> snmp table. Once i find the
> interface index, i can poll status, IN/Out Octets etc...
> The next time the same service get's checked it would be nice to
> pass the last dermined interface
> index, and only test if the index still has the correct IfDescr. To
> do this i rely on temporary files today,
> this is a mess.
> I could pass the index in the $SERVICEOUTPUT$ output, but that could
> potentialy clutter up the information, displayed as the
> check message, i could also use $SERVICEPERFDATA$,but that is used
> for performance data, and get's passed to external performance
> collector stuff.
> I would like to have the possibility for a 3rd field in the check
> output, getting stored in a
> $SERVICETEMPDATA$ which could be used for about anything toaking care
> thath the string will
> be limited in size.
> Kind Regards,
> Peter
> Using Tomcat but need to do more? Need to support web services, security?
> Get stuff done quickly with pre-integrated technology to make your job
> easier
> Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
> http://sel.as-us.falkag.net/sel?cmd=lnk ... dat=121642
> Nagios-devel mailing list
> [email protected]
Content-Type: text/html; charset=UTF-8
Hi again....
status, i
One other post suggested memcache, or database. I will stick with my quic=
k&dirty
/tmp files.... ;)
Eli Stair wrote:
=20
=20
=20
Re: [Nagios-devel] Message passing between host/service check pl=
ugin.
=20
...[email truncated]...
