On Wed, 7 May 2003, Roy Sigurd Karlsbakk wrote:
> On Wednesday 07 May 2003 14:47, Subhendu Ghosh wrote:
> > One list please..
> > As noted in the source...
> > common/objects.h:#define MAX_PLUGINOUTPUT_LENGTH 352 /* max. length of
> > plugin output */
> > This is due to the limation of max size of a non-interleaved write to a
> > pipe on linux.
> what's that limit? 352?
> now can I detail the alerts better?
Depending on your platform's max msg sixe in a pipe, you can adjust the
MAX setting above.
Note there is an overhead associated with massing the message thru the
pipe that is not counted in the MAX setting.
-sg
