This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_001_01C50FBB.BE92C37C
Content-Type: text/plain
Can anyone clarify the instructions for setting up NagMIN after running the
setup scrip?
I got the below output of instructions after running setup. On step 4,
should I be specifying /usr/local/nagmin/nagmin instead of
/usr/local/nagios/etc for the path?
Any help or suggestions are appreciated.
Thanks.
Bill
NagMIN Database Setup Complete
# 1 - Now access WebMIN and install the NagMIN plugin
# 2 - Configure NagMIN Nagios default values clicking Module Config in
WebMIN
# 3 - Edit your database tables and run Verification until you get
# a clean configuration. This will create NagMIN configuration files
in
# /usr/local/nagmin/nagmin/ directory
# 4 - Modify your nagios.cfg and cgi.cfg files to replace configuration
file se
ttings
# with new NagMIN configuration files listed below. This must be done
befo
re
# you can successfully activate your first NagMIN configuration.
# 5 - Run Activate Config. Check the verification output for any errors.
# 6 - Remove any unnecessary configuration files from your
c
# directory.
# 7 - Install the following optional software for full NagMIN
functionality:
# - fping-2.3b1
# - nmap-3.50
# - rrdtool
# - net-snmp-5.0.8
# 8 - Install the following perl modules for full NagMIN functionality
# - Net::SNMP
# - CGI
# - DBI
# - Apache::DBI
# NagMIN Configuration Files
# cfg_file=/usr/local/nagios/etc/Contact.cfg
# cfg_file=/usr/local/nagios/etc/ContactGroup.cfg
# cfg_file=/usr/local/nagios/etc/Host.cfg
# cfg_file=/usr/local/nagios/etc/HostEscalation.cfg
# cfg_file=/usr/local/nagios/etc/HostGroup.cfg
# cfg_file=/usr/local/nagios/etc/HostGroupEscalation.cfg
# cfg_file=/usr/local/nagios/etc/Service.cfg
# cfg_file=/usr/local/nagios/etc/ServiceDependency.cfg
# cfg_file=/usr/local/nagios/etc/ServiceEscalation.cfg
# cfg_file=/usr/local/nagios/etc/ServiceExtInfo.cfg
# cfg_file=/usr/local/nagios/etc/ServiceTemplate.cfg
# cfg_file=/usr/local/nagios/etc/TimePeriod.cfg
Bill Winkles
Lucent Technologies *
Sr. Technical Engineer
Global Network Operations Center - Denver
* +1 720/482-6528 (Voice)
* +1 303/941-2455 (Mobile)
Content-Type: text/html
st1\:*{behavior:url(#default#ieooui) }
/* Font Definitions */
@font-face
{font-family:Wingdings;
panose-1:5 0 0 0 0 0 0 0 0 0;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{margin:0in;
margin-bottom:.0001pt;
font-size:12.0pt;
font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.EmailStyle17
{mso-style-type:personal-c
...[email truncated]...
