Re: [Nagios-devel] nsca and nrpe2 syslog facility
On Nov 20, 2007, at 2:00 AM, Andreas Ericsson wrote:
> Brian A. Seklecki wrote:
>> nsca.c @ line 134 of 1450
>> openlog("nsca",LOG_PID|LOG_NDELAY,LOG_DAEMON);
>> prototype: void openlog(const char *ident, int logopt, int
>> facility);
>> We should probably make that a config-file defined variable. At the
>> *very* least, a GNU autoconf compile-time configure option -> #DEFINE
> Err... say what now?
./configure --with-log-facility=local0
becomes
#define NSCA_SYSLOG_FACILITY LOG_LOCAL0
openlog("nsca", LOG_PID|LOG_NDELAY, NSCA_SYSLOG_FACILITY);
>> Default syslog.conf(5)'s everywhere are going to split the
>> destination
>> into a variety of files (because of priorities), which is insanely
>> annoying.
> First off, let's get one thing straight right from the start.
> Syslog uses a facility and severity pair which, combined, is called
> priority. It's actually a single number, calculated like so:
> pri = (fac
> What people normally do (in my experience) is to put logs from
> different *facilities* in one file, and additionally log LOG_WARN
> or LOG_ERR and above to somewhere else.
This isn't always the case. In some cases you want a specific level of
a specific facility sent to a specific log file. Or if you're using
syslog-ng you want a specific *application* (based on the const char
*ident parameter to openlog, "nsca" in this case) logged to a
particular log.
>> Then we can route it out to destinations regardless of priorities
>> before
>> fall-back facility.priority(*) wildcard gets caught.
> Sure, but since there aren't enough facilities for every program to
> have
> its own, the facilities need to be shared. I fail to see the problem
> here,
> since so far the only ones you've mentioned are downright wrong.
What about LOG_LOCAL0, LOG_LOCAL1, ... LOG_LOCAL7?
