Re: [Nagios-devel] Latency keeps going up.
    I am not using embedded perl, as a mention in my email, but here is
my configure.
./configure --prefix=/usr/local/nagios --enable-event-broker
--with-nagios-user=opuser --with-nagios-group=opuser
--with-command-user=opuser --with-command-group=opuser
--with-httpd-conf=/etc/httpd/conf.d --enable-nanosleep
--disable-embedded-perl
    NDO in not causing this and the nanosleep option either, as the
problem was the same without it last week.
    I am using CentOS 5.
    []s.
Gerd Mueller wrote:
did you try to disable embedded perl?
Cheers,
Gerd
On Mi, 2008-02-13 at 11:24 -0200, Alessandro Ren wrote:
embedded perl
OpSign
__________________________________________________
Alessandro Ren
OpServices
Luciana de Abreu, 471 - Sala 403
Porto Alegre, RS - CEP 90570-060
(   phone 55(51)3061-3588
4    fax 55(51)3061-3588
Q   mobile 55(48)9987-0625
:   email [email protected]
