Re: [Nagios-devel] [Fwd: Re: [Nagios-users] Nagios 3.0b4 crashing]
Andy Shellam (Mailing Lists) wrote:
> Sorry, due to an error on my mail server, this didn't get through first
> time round.
> Hi,
> Found the cause of this: the pre-flight check isn't working correctly
> (see output below) which caused the confusion (the errors were
> off-screen in my terminal window, and I mistakenly trusted the "Total
> Warnings: 0, Total Errors: 0" bit!!
> I've copied in nagios-devel to report this (also confirmed the same with
> today's CVS build.) Note that the servicegroup "Server_Info" does *not*
> exist (I mistakenly removed it a few days ago), so the pre-flight check
> should report it as an error, but it doesn't.
> Nagios 3.0b4
> Copyright (c) 1999-2007 Ethan Galstad (http://www.nagios.org)
> Last Modified: 09-27-2007
> License: GPL
> Reading configuration data...
> Error: Could not find any servicegroup matching 'Server_Info' (config
> file
> '/usr
> /local/nagios.test/etc/services/system-uptime.cfg', starting on line 1)
> file
> '/usr
> /local/nagios.test/etc/services/system-processes.cfg', starting on line 1)
> file
> '/usr
> /local/nagios.test/etc/services/system-name.cfg', starting on line 1)
> file
> '/usr
> /local/nagios.test/etc/services/system-location.cfg', starting on line 1)
> file
> '/usr
> /local/nagios.test/etc/services/system-contact.cfg', starting on line 1)
> file
> '/usr
> /local/nagios.test/etc/services/snmp-uptime.cfg', starting on line 1)
> Running pre-flight check on configuration data...
> Checking services...
> Checked 7 services.
> Checking hosts...
> Checked 1 hosts.
> Checking host groups...
> Checked 1 host groups.
> Checking service groups...
> Checked 1 service groups.
> Checking contacts...
> Checked 1 contacts.
> Checking contact groups...
> Checked 1 contact groups.
> Checking service escalations...
> Checked 0 service escalations.
> Checking service dependencies...
> Checked 0 service dependencies.
> Checking host escalations...
> Checked 0 host escalations.
> Checking host dependencies...
> Checked 0 host dependencies.
> Checking commands...
> Checked 4 commands.
> Checking time periods...
> Checked 1 time periods.
> Checking for circular paths between hosts...
> Checking for circular host and service dependencies...
> Checking global event handlers...
> Checking obsessive compulsive processor commands...
> Checking misc settings...
> Total Warnings: 0
> Total Errors: 0
> Things look okay - No serious problems were detected during the
> pre-flight check
> Thanks,
> Andy
[snip]
Thanks for the report. I tracked down this bug and will post a fix to
CVS shortly.
Ethan Galstad,
Nagios Developer
Email: [email protected]
