Re: [Nagios-devel] Patchs proposal
On 17 May 2009, at 14:20, Andreas Ericsson wrote:
> I modified it quite extensively, but I've committed
> it to Nagios CVS. The effects of it will be in the next nagios
> release,
> but the exact code you wrote is not there. Check out latest CVS and
> have a look in base/config.c and you'll see how it turned out.
I'm getting an error when I run "make nagios" where it says:
Undefined symbols:
"_xodtemplate_unset_service_is_from_hostgroup", referenced from:
_xodtemplate_begin_object_definition in xobjects-base.o
I've done a "make distclean && ./configure && make nagios" and I still
get this problem. Presumably this is working for your system?
Ton
