is not that easy to understand.
On 21 Oct 2004 at 10:35, Michael Medin wrote:
> Hi,
> This is a simple patch that allows (or so I hope) availability reports
> to be made based on a time period. What this means is that I can
> generate reports for other timeframes then 24x7.
> We use this internally to generate availability reports for some of
> our systems that have an 8x5 SLA. How this works and is implemented is
> that on the last page of the availability report you can select a
> predefined timeperiod and then only time during that period is counted
> towards the avalibility report.
> This means that for our SLA which is 9-5 mon-fri I can generate
> avalibility reports for that timeframe but still monitor 24x7.
> As I stated before I don't know that much about nagios development so
> if this is implemented badly, have bugs or plain out doesn't work
> please let me know
> BTW; the "patch" has been generated with tortouise so it might
> possibly not follow whatever standard patches should but I could apply
> it to my Linux box sp hopefully it will work.
> // Michael Medin
Ethan Galstad,
Nagios Developer
Email: [email protected]
