Ton Voon wrote:
> Hi!
> I've raised a bug report in Mantis re: double escaping: http://tracker.nagios.org/view.php?id=56
> I'm convinced this is bad behaviour, but want some confirmation
> (Ethan? Andreas?) that this is correct action before I spend the time
> in making changes, especially as it is likely to break existing
> configurations too.
> Comments?
> Ton
I believe this behavior was requested by users quite a while back.
Changing it will likely break many configurations. Better to make sure
the current behavior is well documented, than change it I think...
- Ethan Galstad
