On Tue, 2003-04-22 at 18:36, Stanley Hopcroft wrote:
> > I think, that RFC-1035 was obsolete?
> Thanks for pointing this out. I don't know the details but 1123 says
> 2.1 Host Names and Numbers
> The syntax of a legal Internet host name was specified in RFC-952
> [DNS:4]. One aspect of host name syntax is hereby changed: the
> restriction on the first character is relaxed to allow either a
> letter or a digit. Host software MUST support this more liberal
> syntax.
> Host software MUST handle host names of up to 63 characters and
> SHOULD handle host names of up to 255 characters.
> This suggests that the is_hostname function in plugins/utils.c is wrong
> and should be modified accordingly, however I think I should start
> shutting up here, because my former comments were _wrong_ (the obsolete
> 1.2.9 plugins used the incorrect is_hostname() in utils.c) .
> The code from this years CVS has is_hostname() in netutils.c and this
> uses getaddrinfo() to do gethostbyname_ctx (??).
> So to sum up, If you haven't done so already, try the CVS plugin code or
> the latest release from SourceForge.
> If it doesn't build, post a bug report
> If it doesn't work and your resolver is happy with your hostname, post a
> bug report.
> Sorry for wasting everyones time.
Not a waste of my time. You just saved me from tracking down the RFC.
I will chnge the plugin in the 1.3.x branch
Karl
