Re: [Nagios-devel] Template befor Definition
Mark Eisenblaetter wrote:
> Hi,
> for my distributed monitoring it would be great if i where possible to
> say:
> Use the Template and not the option set in the definition.
> My problem is that when i have an active check on an distributed server it
> is passiv on the master.
> I control this beavior with the template system (diffrend templates on
> maser/slave)
> But i if use check_freshness on the master it will use the check_command and
> f.e pings the Host which could get me the wrong results
> if for example the ip address on both location pingable but differend server
> i will get the wron result.
> so it would be great if i can say in the template use the check_command
> (check_dummy) defined in the template and not that defined in the Host.
That's what not setting anything in the object itself is for. If you don't
have a check_command in the host object, it will use the one from the
template.
OP5 AB www.op5.se
