Re: [Nagios-devel] Daemonizing Logic Error
Devin Bayer wrote:
> Hello:
> We faced an issue when nagios silently failed to fork. Since it's
> part of our startup scripts, this delayed the rest of the daemons
> until nagios exited.
While it's bad that Nagios fails to daemonize OR die properly, your
startup-script parser really shouldn't hang indefinitely when it
encounters a start-script that doesn't return. I believe this should
be bug-reported to your distribution-vendor separately.
> For this reason nagios should take care, that if
> it doesn't daemonize correctly, it should die. We are using nagios
> 3.0.5, but I see the bug still exists in the trunk. Here is our
> nagios.log showing the problem:
> [1242115575] Nagios 3.0.5 starting... (PID=773)
> [1242115575] Local time is Tue May 12 11:06:15 EEST 2009
> [1242115575] LOG VERSION: 2.0
> [1242115575] Finished daemonizing... (New PID=773)
Right. This is indeed odd.
> Notice the "New PID" equals the old PID. I think this is the problem
> code, from base/utils.c:
> 2036 : /* check for SIGHUP */
> 2037 : if(val==1 && (pid=(pid_t)pidno)==getpid()){
> 2038 : close(lockfile);
> 2039 : return OK;
> 2040 : }
> If nagios is started at boot time, it's somewhat likely it will have
> about the same PID on the next boot. So if the lockfile isn't cleaned
> for some reason, then nagios will start, read the lockfile, and not
> fork.
> 2042 : /* exit on errors... */
> 2043 : if((pid=fork()) 2044 : return(ERROR);
> This looks like another bug. If fork fails, we return ERROR, but the
> return code is just silently ignored.
Hmm. I'll look into this and see what may be done. Thanks for the report.
OP5 AB www.op5.se
Register now for Nordic Meet on Nagios, June 3-4 in Stockholm
http://nordicmeetonnagios.op5.org/
on peace.
