[Nagios-devel] Re-reading of config files with no interruption
Hello list,
1. There should be a way of letting the nagios process reread its =
config-files without restarting it. Ideally, this would not interrupt =
ongoing checks. Any plans to make this happen in 2.0?
A couple of ideas on how to make it work, based on how other programs do =
it. From the DNS world:
A. The traditional bind / kill -HUP approach. Hmmm. Generally one =
shouldn't have to send signals to a process for it to see that its own =
configuration has changed. Besides, it can be hard for the process to =
catch the signal in the right way in all possible situations.=20
B. The tinydns / make approach. Once you've edited your config files, do =
a "make" (eg. in the etc catalogue). If there's no errors in the =
config-files, make will change some other file. For tinydns the config =
is compiled to cdb, not necessarily what we want for Nagios. Anyway, =
Nagios monitors the changes of this file, say every minute, and when =
it's changed will know it's supposed to reread its configuration. A =
simplification of this approach would be to just require users to touch =
a non-config file in the etc directory whenever nagios is to reread its =
config.
2. Other ideas?
:) Bj=F8rnar
