Re: [Nagios-devel] Nagios3.0b4 : shutdown after a few minutes
Thanks Hendrik!
Hendrik Bäcker wrote:
> Hi List,
> hi Ethan,
> the patch works.
> Latest CVS code is running since last friday without any Problems.
> Regards
> Hendrik
> Ethan Galstad schrieb:
>> FYI - I just posted a "patch" that disables the $SERVICEGROUPMEMBERS$
>> macro. I tend to think that another problem elsewhere is the real root
>> cause, but I'm not sure. If anyone ran into this bug, please try the
>> latest CVS code and see if it fixes the problem. Thanks.
Ethan Galstad,
Nagios Developer
Email: [email protected]
