Re: [Nagios-devel] Strange characters in output when
Hi List,
I am able to reproduce this with the current cvs version and build a
small perl script for possible testers:
libexec/epnplugin.pl
#!/usr/bin/perl
# Test Plugin
print "CRITICAL - Test down\n";
exit 3;
commands.cfg
command_name epntest
command_line $USER1$/epnplugin.pl
I think a service definition will not be a problem for the most of the
readers here ;)
(ok... for the case)
name generic-service-epn
active_checks_enabled 1
passive_checks_enabled 1
parallelize_check 1
obsess_over_service 1
check_freshness 0
notifications_enabled 1
event_handler_enabled 1
flap_detection_enabled 1
failure_prediction_enabled 1
process_perf_data 1
retain_status_information 1
is_volatile 0
check_period 24x7
max_check_attempts 3
normal_check_interval 10
retry_check_interval 2
contact_groups admins
notification_options w,u,c,r
notification_interval 60
notification_period 24x7
register 0
# Local service definition template - This is NOT a real service, just a
template!
name local-service-epn
use generic-service-epn
max_check_attempts 4
normal_check_interval 5
retry_check_interval 1
register 0
use local-service-epn
host_name localhost
service_description epntest
check_command epntest
Peter Ringe schrieb:
> Hi Ingo,
> Hi all,
> at least Im sure there is a problem with the epn concering Plugin-Output.
> I remarked this already some month ago for 3.0a1 and looking for other
> guys,
> seeing the same problem. ([Nagios-devel] problems epn with 3.0a1 ,
> 21.03.2007)
> In between there have been some more discussion concerning epn that the
> plugin result
> is scrambled up Inside the empedded Perl, the plugin putput is correct,
> but when the output reaches
> nagios, the first 4 or 8 byte of Plugin Output seems to be overwritten.
> I do not understand embedded perl in detail, but perheaps there is
> someone else, who can
> have a look at that problem.
> I think it's a real problem for nagios 3.0, because a lot of people use
> epn due to perfomance.
> All those guys cannot switch over to nagios 3.0 without epn.
> Regards
