I had the same problem, tried everything and nothing seemed to work.
Then I decided to downgrade to ndoutils 1.3.1 and everything worked just
fine. Try that.
On mié, 2007-02-28 at 02:20 +0200, naim abu darwish wrote:
> hi, i googled tried the other fixes people suggested, nothing seems to
> work, the ndo2db-2x is running but not socket is created, some configs::
> /etc/nagios/ndo2db.cfg::
> ndo2db_user=nagios
> ndo2db_group=nagios
> socket_type=unix
> socket_name=/var/nagios/ndo.sock
> tcp_port=5668
> db_servertype=mysql
> db_host=localhost
> db_port=3306
> db_name=nagios
> db_prefix=nagios_
> db_user=ndouser
> db_pass=some_verified_password
> max_timedevents_age=1440
> max_systemcommands_age=10080
> max_servicechecks_age=10080
> max_hostchecks_age=10080
> max_eventhandlers_age=44640
> localhost nagvis # ls -l /var/nagios/ndo.sock
> srwxr-xr-x 1 nagios nagios 0 Feb 27 03:12 /var/nagios/ndo.sock
> localhost nagios # fuser 5668/tcp
> localhost nagios #
> also :: i tried both tcp and unix sockets, changing the output_type
> accordingly, no luck
> also below is /etc/nagios/ndomod.cfg ::
> instance_name=default
> output_type=tcpsocket
> output=/var/nagios/ndo.sock
> tcp_port=5668
> output_buffer_items=5000
> buffer_file=/var/nagios/ndomod.tmp
> file_rotation_interval=14400
> file_rotation_timeout=60
> reconnect_interval=15
> reconnect_warning_interval=15
> data_processing_options=-1
> config_output_options=2
> running on nagios 2.5, php5.1.6-pl6, compiled ndoutils-1.4b2 with gcc 4.1.1
> Some logs below ::
> [1172540517] ndomod: Successfully flushed 113 queued items to data sink.
> [1172540517] ndomod: Error writing to data sink! Some output may get
> lost...
> [1172540533] ndomod: Successfully reconnected to data sink! 0 items lost,
> 114 queued items to flush.
> [1172540533] ndomod: Successfully flushed 114 queued items to data sink.
> [1172540533] ndomod: Error writing to data sink! Some output may get
> lost...
> Any help appreciated
> Take Surveys. Earn Cash. Influence the Future of IT
> Join SourceForge.net's Techsay panel and you'll get the chance to share your
> opinions on IT & business topics through brief surveys-and earn cash
> http://www.techsay.com/default.php?page ... CID=DEVDEV
> Nagios-devel mailing list
> [email protected]
