[Nagios-devel] [PATCH] NDOUTILS Fix: The ndo2db debug file should
--------------030904050901050507080208
Content-Type: text/plain; charset=UTF-8
Hash: SHA1
Hi Devels,
Lars M. has detected a small file based race condition in ndo2db causing
the debug file creation before dropping the privileges to ndo2db_user.
Attached patch should solve the problem.
Thanks to Lars bringing this to attention.
Regards,
Hendrik
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.8 (Darwin)
iEYEARECAAYFAkke8Q4ACgkQlI0PwfxLQjmC3QCfcSbN1jOO8Sv7fDQ4CdcNxmKl
EuMAn1sOR70QySrInGHWm9GqiQS94a1+
=h0oS
-----END PGP SIGNATURE-----
Content-Type: text/x-patch;
name="bf6cd0f038495530896ee16c1e5491eb80f72280.diff"
Content-Disposition: inline;
filename="bf6cd0f038495530896ee16c1e5491eb80f72280.diff"
diff --git a/src/ndo2db.c b/src/ndo2db.c
index 19698c4..7a0fcc7 100644
--- a/src/ndo2db.c
+++ b/src/ndo2db.c
@@ -109,9 +109,6 @@ int main(int argc, char **argv){
exit(1);
- /* open debug log */
- ndo2db_open_debug_log();
/* make sure we're good to go */
if(ndo2db_check_init_reqs()!=NDO_OK){
printf("One or more required parameters is missing or incorrect.\n");
@@ -146,6 +143,9 @@ int main(int argc, char **argv){
/* drop privileges */
ndo2db_drop_privileges(ndo2db_user,ndo2db_group);
+ /* open debug log */
+ ndo2db_open_debug_log();
/* if we're running under inetd... */
if(ndo2db_use_inetd==NDO_TRUE){
--------------030904050901050507080208--
