--------------040501000208000701060706
Andreas Ericsson wrote:
> On 01/03/2011 03:13 PM, Carsten Emde wrote:
> Applied and pushed. Thanks
Nice patch, thanks. It contains several inline declarations which i have
reworked while applying against Icinga CGIs. Attached is a git patch
against current Nagios HEAD (from git.op5.org, thx for the mirror)
resolving those things too.
Kind regards,
Michael
DI (FH) Michael Friedrich
Vienna University Computer Center
Universitaetsstrasse 7 A-1010 Vienna, Austria
email: [email protected]
phone: +43 1 4277 14359
fax: +43 1 4277 14338
web: http://www.univie.ac.at/zid
http://www.aco.net
Icinga Core& IDOUtils Developer
http://www.icinga.org
Content-Type: text/x-diff;
name="0001-fix-inline-declarations-in-trends.cgi-from-previous-.patch"
filename*0="0001-fix-inline-declarations-in-trends.cgi-from-previous-.pa";
filename*1="tch"
From 2f9caa7268402fe4b25d669094594402eaa26819 Mon Sep 17 00:00:00 2001
Date: Fri, 7 Jan 2011 09:18:11 +0100
Subject: [PATCH] fix inline declarations in trends.cgi from previous patch
cgi/trends.c | 14 ++++++++++----
1 files changed, 10 insertions(+), 4 deletions(-)
diff --git a/cgi/trends.c b/cgi/trends.c
index 9f3f481..60dde4d 100644
--- a/cgi/trends.c
+++ b/cgi/trends.c
@@ -266,6 +266,12 @@ int main(int argc, char **argv){
time_t t3;
time_t current_time;
struct tm *t;
+ time_t old_t1;
+ time_t old_t2;
+ archived_state *temp_as;
+ time_t problem_t1=0;
+ time_t problem_t2=0;
+ time_t margin;
/* reset internal CGI variables */
@@ -365,7 +371,8 @@ int main(int argc, char **argv){
if(mode==CREATE_HTML && display_header==TRUE){
- time_t old_t1=t1, old_t2=t2;
+ old_t1=t1;
+ old_t2=t2;
/* begin top table */
printf("\n");
@@ -384,8 +391,8 @@ int main(int argc, char **argv){
display_info_table(temp_buffer,FALSE,¤t_authdata);
if (timeperiod_type==TIMEPERIOD_NEXTPROBLEM) {
- archived_state *temp_as;
- time_t problem_t1, problem_t2=0;
+ problem_t1=0;
+ problem_t2=0;
t1=t2;
t2=current_time;
@@ -427,7 +434,6 @@ int main(int argc, char **argv){
if(problem_found==TRUE) {
- time_t margin;
if (problem_t2==0){
margin=12*60*60;
1.7.1.1
--------------040501000208000701060706--
