Re: [Nagios-devel] Minor distributed monitoring documentation error
Goldschrafe, Jeffrey wrote:
> In the middle of the documentation for the distributed monitoring
> configuratoin, there's an example script used to submit NSCA results to
> the master server from an OCSP/perfdata processor. That script contains
> this command:
> /bin/printf "%s\t%s\t%s\t%s\n" "$1" "$2" "$return_code" "$4" |
> /usr/local/nagios/bin/send_nsca central_server -c
> /usr/local/nagios/etc/send_nsca.cfg
> It's missing the -H argument before central_server, though, so it should
> read as follows:
> /usr/local/nagios/bin/send_nsca -H central_server -c
> The script should probably also just define $CENTRAL_SERVER at the top
> of the script somewhere in keeping with good scripting form, but that's
> a nitpick -- the missing switch is the big concern. :)
Thanks for the note Jeff - CVS will be updated shortly.
Ethan Galstad
Nagios Developer
___
Email: [email protected]
Web: www.nagios.org
